kebetulan nemu, terus mau di terbangin, mohon masukkannya, dulu nggak terbang karena batterainya aneh.....300mAh 2 cells.....
sangat pas untuk pensiunan seperti saya yang sudah uzur dan tidak mampu terbang jauh2
Product Specifications
Wingspan: 14.7 in (374mm)
Overall Length: 15.7 in (400mm)
Wing Area: 83.8 sq. in. (54.2 sq. dm.)
Flying Weight: 2.54 oz (72 g)
Motor Size: BL180 2,500Kv brushless outrunner
Radio: 4 channel minimum
Trim Scheme Colors: Black, Red, Silver
CG (center of gravity): 19mm back from L.E. of bottom wing
Wing Loading: 3.4 oz/sq ft (1.01 g/sq dm)
Prop Size: 5 x 2.75 inch
Recommended Battery: 2S 7.4V 180mAh LiPo
Control Throw (Ailerons): Low: 70%, 0% expo; High: 100%, 0% expo
Control Throw (Elevator): Low: 70%, 0% expo; High: 100%, 0% expo
Control Throw (Rudder): Low: 70%, 0% expo; High: 100%, 0% expo
Approx. Flying Duration: 5 minutes
Minimum Age Recommendation: 14 years and above 40 years
Experience Level: Intermediate
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
Needed to Complete
Recommended
- 4+ channel DSM2- or DSMX- compatible Transmitter
- Flight Battery
- Charger and Adapter for flight battery (Celectra 2S Li-Po Charger does not require an adapter)
