dji wookong
Moderator: aan
- abdullah
dji wookong
saya tdk tau pesawat ini dalam katagori heli atau pesawat,akhirnya saya putuskan untuk masuk katagori heli elektrik ini,saya mohon petunjuk dan bimbingannya kepada para suhu2:
heli ini saya beli di hobby-wing,jenis heli dji f550 wookong+DJI Wookong Flight Controllers WK-M, setelah saya rakit semua, saya konekkan di Rx,ke 6 motor tdk bisa berputar, cuma berbunyi tulit2,
mohon petunjuk, trima kasih
- abdullah
Re: dji wookong
spec yg saya terima :
1x F550 Frame
6x DJI OPTO 30A ESC
6x DJI 1045 Propeller
6x DJI2212 MOTOR
1x DJI NAZA FC
1.Built-in Function: Autopilot/Auto Hover Fail Safe
2.Multi Rotor Types: Quad-Rotor/Hex-Rotor/Octo-Rotor
3.Supported ESC output: 200Hz refresh frequencys
4.Operating Temperature: -5¡ãC to +60¡ãC (You have to keep the IMU warm if you want to use it under low temperature, could be -5¡ãCor lower.)
5.Flight Performance (can be effect by mechanical performance)
6.Hovering Accuracy: Vertical: ¡À 0.5m, Horizontal: ¡À 2m
7.Suitable Wind Condition: upto 8m/s (17.7mph)
8.Max Rotate Angle: 30¡ã Vertical Speed: 3m/s
9.Radio Frequency: 900 MHz or 2.4 GHz
10.Data-Throughput: 11,520 bps
11.Communication(Open air): upto 3km (2.4GHz 2dbi antenna) upto 10km (900MHz 2dbi antenna)
12.Dimention:
Main controller:61mm x 39.6mm x 15.8mm
IMU:40mm x 31mm x 26mm
GPS&Compass:50mm (diameter) x 9mm
LED Indicator:25mm x 25mm x 7mm
1x F550 Frame
6x DJI OPTO 30A ESC
6x DJI2212 MOTOR
1x DJI NAZA FC
12.Dimention:
- sudjai sarmo
Re: dji wookong
Sayang tak ada gambarnya.
- orchiplane
Re: dji wookong
upload gambarnya om biarseru diskusinya..
- abdullah
Re: dji wookong
mohon maaf,barangnya ada di kantor,menyusul hari senin,biasa di rumah ada bos besar,hahaha
- panjitohaga
Re: dji wookong
F550? Hexacopter dong yah, mantab nih om...coba minta dipindahin om moderator ke ruang quadcopter (atau sejenisnya) biar bisa dapat support dari om2 yg maen quad.
- abdullah
Re: dji wookong
panjitohaga wrote:F550? Hexacopter dong yah, mantab nih om...coba minta dipindahin om moderator ke ruang quadcopter (atau sejenisnya) biar bisa dapat support dari om2 yg maen quad.
trima kasih atas sarannya om panji,..
- abdullah
- dedy_r450
- Captain
Re: dji wookong
abdullah wrote:saya tdk tau pesawat ini dalam katagori heli atau pesawat,akhirnya saya putuskan untuk masuk katagori heli elektrik ini,saya mohon petunjuk dan bimbingannya kepada para suhu2:
ada proses upload firmwarekedalam controler, apakah sudah dilakukan?
pada firmware ada beragam seting, (pemilihan mixing motor, posisi imu, arah imu, kalibrasi tx)semua harus dilakukan dulu.
- abdullah
Re: dji wookong
dedy_r450 wrote:abdullah wrote:saya tdk tau pesawat ini dalam katagori heli atau pesawat,akhirnya saya putuskan untuk masuk katagori heli elektrik ini,saya mohon petunjuk dan bimbingannya kepada para suhu2:
terima kasih om dedy, saya lakukan setting di komp motor berapa yg akan dipergunakan, krn ini pakai 6 motor, saya pilih 6. perna juga saya coba 1 esc+motor saya konekkan di Rx,bunyinya sama tulit2,apa esc+motor jenisnya sama dengan motor+esc yg dipergunakan pesawatatau heli elektrik.
