Tutorial Swash Plate Leveling
Forum rules
FOUNDER
FOUNDER
Intro :
Setting swash leveling sangat penting untuk memastikan swash plate selalu level pada posisi low,middle dan high .
Swash plate leveling adalah langkah awal dalam merakit heli 6 channel.
Juga merupakan langkah yang harus dicheck setelah heli Anda crash.
Berikut ini adalah contoh bagaimana me-level swash plate
T-Rex 500 Swash Lever User Guide
Step 1 Before starting lets remove the head from the T-Rex 500. This will be required to use the swash plate leveler and removing it first eliminates the possibility of spooling up on the workbench. Simply remove the head block bolt and the 4 links that attach to the swash plate.
Step 2 Next we need to clear out any unwanted settings in the transmitter. These numbers will be re-adjusted using the swash plate leveler. Check to be sure that the sub trim is set to 0 for the elevator and aileron channel.
Step 3 Check to be sure that the sub trim is set to 0 for the pitch channel.
Step 4 Check to be sure that the travel adjustment for the elevator and aileron channels are set to 100 in both directions.
Step 5 Check to be sure that the travel adjustment for the pitch channel is set to 100 in both directions.
Step 6 Next you need to move your collective stick to center. Use the pitch curve adjustment page to ensure you are at exactly 50% pitch. Make sure that you are in throttle hold or the motor is not connected. By moving your collective stick to center the 3 CCPM servos should be in the center of their travel.
Step 7 Place the control horn on the servo on the left side of your helicopter. Make sure it is on the spline which keeps it as close as possible to exactly 90 degrees. If your control horn has more than one arm, rotate the arm and try them all for the one with the best angle. Note: Your control horn may require the use of sub trim to get exactly 90 degrees. If you are using a horn with 4 sides its very likely that one of them will be correct. If you are using a horn with a single arm, it will most likely not be at the correct angle. In this case it is okay to use some sub trim on that specific servo to get the arm to 90 degrees.
Step 8 Next we will center the elevator servo. Like we did for the pitch servo, first put the servo arm onto the servo so it is closest to parallel with the servo case. Some sub trim is acceptable if necessary to get to 90 degrees.
Step 9 Place the last control horn on the servo on the right side of the helicopter. Again be sure to use the best arm on your control horn and a small amount of sub trim if necessary to get it level.
Step 10 Now that all your servos are completely centered we are ready for the leveling tool. Double check that your TX has the collective stick centered and all 3 CCPM servo arms are where we set them.
Step 11 Slide the swash plate leveler down on the main shaft and onto the swashplate. At this point we will be leveling the swash at 0 pitch. Because we have already done the centering to the servos, all adjustments will be made with the link lengths.
Step 12 Match the tool arms up with the swash plate CCPM points. For a perfectly level swash you will need to adjust the links until the tool touches the swash at all 3 points. I usually leave the elevator servo link as a reference since its more of a pain to adjust. Adjust the aileron and pitch servo links until the leveler touches all three points.
Step 13 Here is a photo of the point at the correct length. Check to make sure all 3 of the points are touching the swash plate and no light can be seen between the leveler and the swash.
Step 14 Now that center has been leveled, we need to level the endpoints. Move the collective stick to full positive pitch. Now recheck your swash with the leveling tool. I'm willing to bet that it is no longer level. This is because your servos are not perfectly matched.
Step 15 To level these points you need to adjust the endpoint travel of each of the servos. The rods are already the correct length, and the servos are already where we want them, so messing with those will not help the situation. For the points that are not touching the leveling tool, just add some extra travel until that point comes up and touches the tool. You may also decrease the travel of those points that are too high, either method works. The end result should be a level swash the same as we have at center stick. The photo is of the travel menu in the DX7 before adjustments have been made.
Step 16 The last step in getting a perfect level setup is leveling the negative part of the collective range. We will do this exactly the same as we did for the positive. Move the collective stick all the way to the bottom and again adjust the travel of each channel until the leveler hits all 3 points on the swash plate.
FINISHED! You now have a perfectly leveled swash plate. Put the rotorhead back on the helicopter and go fly. You should find the helicopter is trimmed out after using this tool. Should the helicopter not be in trim, read the page called "Trimming your T-Rex" for more details.
source : http://www.truebloodengineering.com
biar jelas kita tambah video dari sumber lain :
link : http://www.youtube.com/watch?v=k_2RJ9YS7dA
related link :
Swash leveling Trex 450
Swash Leveling Trex 500
Swashplate leveling using zip ties ( video )
FOUNDER
FOUNDER
Re: Tutorial Swash Plate Trex 600 by Budiman
Budiman wrote: Hal pertama yang biasa saya lakukan :
1. Memeriksa panjang setiap linkage rod pada heli berdasarkan ukuran yang disebutkan dalam manual T-Rex 600 Nitro
2. Semua servo bergerak sesuai dengan arahnya masing2, artinya jika ada yang terbalik arah nya, maka fungsi "Reverse" pada di Radio dapat digunakan untuk memperbaiki servo yang bersangkutan.
3. Fungsi EPA(End Point Adjustment) atopun ATV pada masing2 servo, biarkan pada nilai 100% semua pada awalnya dan Trim/sub trim pada nilai 0% semua.
4.Fungsi "Swash Mix" pada Aeleron, Elevator dan Pitch set pada nilai 50% masing2.Jika ada yang terbalik tinggal diubah nilai + atopun nilai -,...misalkan pitch mix terbalik pada +50% maka dpat diubah dengan -50%
5. Fungsi "Throttle Hold" pada radio perlu Anda assign pada toggle switch mana saja yang menurut Anda nyaman. Biarkan pada nilai 0% dulu.
Hal kedua yang biasa saya lakukan :
Swashplate
Swashplate saya usahakan untuk level pada setiap gerak. Untuk itu, saya harus memastikan bahwa masing2 servo harus :
1. memposisikan setiap horn nya pada sudut 90 deg ato tegak lurus terhadap shaft pada saat semua stick pada posisi di tengah.
2. setiap servo bergerak sesuai degan arah nya masing2
3. pada saat horn servo pada posisi 90 deg yg kita anggap sebagai titik tengah, maka horn juga harus memiliki ruang gerak yang sama besar saat servo bergerak dari 90 deg ke 0 deg serta sama besar saat bergerak dari 90 deg ke 180 deg.
4. Fungsi "swash mix" telah sesuai ke segalah arah. Jika terbalik,maka nilai prosentase pada menu ini untuk masing aeleron, elevator dan pitch dapat di-ubah2 dari positif ke negatif dan sebaliknya.Sekarang tergantung mana yang bermasalah, apakah aeleron, elevator atopun pitch
Yang perlu Anda perhatikan adalah hindari terjadinya tarik menarik antara servo2 yang terlibat pada CCPM system di Swashplate...misalkan servo salah arah dan terjadi "binding" antar servo. Soal salah arah untuk masing2 servo dapat diatasi dengan fungsi "Reverse" dapat .Sedangkan jika terjadi "binding" antar servo maka yang dapat dilakukan adalah sebagai berikut :
1. mengurangi ato menambah EPA pada servo yang bermasalah
2. melakukan adjustment pada linkage rod, seperti memperpanjang atopun memperpendek.
3. memindahkan posisi ball-link pada servo horn
Jika semua aspek yang telah saya sebutkan di atas dapat Anda pahami dan aplikasikan maka Anda akan mendapatkan range pitch sekitar -10,5 deg sampai dengan +10 deg.
Dan swashplate akan berposisi sebagai berikut saat servo horn 90 deg(pitch 0 deg)
Image Image Image Image
Dan ini adalah saat servo horn pada posisi 90 deg(pitch 0 deg)
Image Image
Untuk membuktikan bahwa swashplate bergerak sama besar baik pada fungsi aeleron dan elevator adalah sebagai berikut
Catatan, dikarenakan saya menggunakan D/R (Dual Rate) pada aeleron dan elevator masing2 sebesar 95%, maka yang saya dapatkan adalah swash degree sebesar +- 6 deg
Elevator down -6 deg
Image Image
Elevator up +6 deg
Image Image
Aeleron -6deg
Image Image
Aeleron +6deg
Image Image
Dan dibawah ini adalah bagaimana heli diposisikan untuk pengukuran di atas
Elevator check
Aeleron check
Throttle
Berikut ini adalah bila kita set nilai prosentase throttle curve pada titik tengah 50%
Dan Throttle pada posisi 100%
Untuk throttle,Anda harus usahakan untuk mendapatkan hasil yang kurang lebih seperti di atas..meng-utak atik EPA dan linkage pada servo throttle dapat membantu Anda
Saya menggunakan Throttle curve sebagai berikut :
0%, 37%, 65%, 84% dan 100%
Sedangkan pitch curve 0 - 100% saya mendapatkan -10.5 deg sampai dengan +10.5 deg
Dan pitch untuk hover saya menggunakan -5deg, +3.5 deg, +4.5 deg, +5.5deg dan +10.5 deg
Saya tidak bisa menjelaskan bagaimana tuning governor pada heli Anda.Setting throttle di atas adalah dalam kondisi tidak menggunakan Governor.
Throttle hold ,Anda harus set untuk safety reason, berapa banyaknya tergantung selera, yang penting engine mampu untuk 'langsam' tanpa mati.
Pada prinsipnya adalah EPA, sub trim/trimm, serta panjang setiap linkage dapat digunakan sebagai cara untuk mendapatkan kondisi di atas. Mana yang akan digunakan,silahkan Anda untuk memilihnya..
berikut adalh modifikasi yang saya aplikasikan pada T-Rex 600 Nitro untuk mendapatkankarakter hover yang stabil.
Flybar lebih pendek dan paddle yang berbeda dari original ALIGN
