New HD Camcoder & FPV Camera
Forum rules
Sekarang banyak bermunculan kamera2 FPV yg di klaim sebagai HD Camera
Saya coba tampilin beberapa yg sudah populer dan akan menjadi populer
(saya enggak mereview product ya , karena enggak punya cameranya. Juga enggak membandingkan satu sama lain, ini sekedar berbagi aja)
Re: HD Camcoder & FPV Camera
HoryzonHD Full HD 1080p FPV camera V2
New features of V2:
1. New sensor module, better image and video quality.
2. Horzyonhd V-reg added. support voltage input from 5-28V
3. Better keypad ribbon wire and easier to use keypad.
4. auto on function, no power on/off button.
Parameters
Lens: 140 degree wide angle.
Sensor: 5.0 Megapixels CMOS
Video resolution:
-1920x1080 30fps
-1440x 1080 30fps
-1280x720 30fps
-1280x720 60fps
Photo resolution: 2592x1944
Video formate: H.264 encoding, Mov
Audo: built-in Microphone
Memory: Support Micro SD card(TF card) up to 32 GB
Power supply: 4.2V DC(5-28V with V-REG)
Your Purchase will include:
1x HoryzonHD 1080P camera
1x HoryzonHD V-REG
1x USB cable
1x avout cable
Av out wire Pin definition :
Black—GND
Green-- Video out
White---Audio out
New features of V2:
Parameters
Video resolution:
-1920x1080 30fps
-1440x 1080 30fps
-1280x720 30fps
-1280x720 60fps
1x HoryzonHD V-REG
1x USB cable
1x avout cable
Black—GND
Green-- Video out
White---Audio out
Re: New HD Camcoder & FPV Camera
Go Pro Hero3
Optics
• Ultra sharp ƒ/2.8 6-element aspherical glass lens
• Ultra wide angle / reduced distortion
Video (NTSC/PAL)
Video Resolution NTSC fps PAL fps STD Mode Protune Mode Field of View (FOV) Screen Resolution/ Aspect Ratio
1080p 30 fps 25 fps YES NO Medium 1920x1080 16:9
960p 30 fps 25 fps YES NO Ultra Wide 1280x960 4:3
720p 60, 30 fps 30, 25 fps YES NO Ultra Wide 1280x720 16:9
WVGA 60 fps 60 fps YES NO Ultra Wide 848x480 16:9
• Video format: H.264 codec, .mp4 file format
• White Balance: manual (with Protune)
Photo Modes
• 5MP resolutions
• Burst: 3 photos per second
• Time-lapse: 0.5, 1, 2, 5, 10, 30, 60 second intervals
Battery & Charging
• 1050mAh rechargeable lithium-ion
• Charge via USB
Audio
• Mono, AAC compression w/ AGC
Storage
• Memory:
o MicroSD class 4 or higher required
o MicroSD Class 10 required for 0.5 timelapse
o Up to 64GB capacity supported
• Record times will vary with resolutions and frame rates
Optics
Video (NTSC/PAL)
Photo Modes
• 5MP resolutions
Battery & Charging
• Charge via USB
Audio
Storage
• Memory:
HD19 ExplorerHD Full HD 1080p FPV Video Camera with Integral Recorder
Features:
• Designed for FPV, shield in aluminium housing
• Compact size, light weight - only 58g!
• Easy to change the lens
• 7-16v wide range voltage input
• 146 degrees wide view angle with clear PAL/NTSC analog video output
• Firmware update supported
• Full HD recording supported
• Radio-controlled HD record, you can utilize a channel of your radio system to control your HD Camera to initialize recording
Specs:
Image sensor: 1/2.5" CMOS
Effective pixel: 5 mega pixels
Lens: 3.15mm
View angle (FOV): 146 degrees
Still picture resolution & file format: 2592*1944 JPEG
Motion picture frame rate/resolution/screen ratio:
1920×1080 (30FPS) 16:9
1440×1080 (30FPS) 4:3
1280×720 (60FPS) 16:9
1280×720 (30FPS) 16:9
Recording medium: High-speed Micro SD card(TF card) capacity up to 32GB
Dimensions: 37x37x31mm
Weight: 58g (memory card and battery weight not included)
Features:
Specs:
Lens: 3.15mm
- dheem2
wah mas, GoPro Hero 3-nya jangan bahas yang silver & white edition mas.. Yang silver n white mah cuman Gopro Hero 2 ganti body.. trus dicap Hero3..
Coba bahasnya yang Black edition:
720p 120fps >> super slow-mo
1080p 60 fps >> slow-mo
1440p 48 fps (ini bukan 1440 x 1080 yah, tapi 2560 x 1440)
4K res 12 fps
Color space untuk videonya udah Protune, alhasil warna video lebih flat, detail jauh lebih bagus.. (standard untuk action camera di production house)
Pokoknya kemampuan action cam dikali dua deh dibanding sama pesaingnya..
Justru karena kemampuan ini yang bikin Gopro Hero 3 Black Edition jadi rajanya action camera. Ya mungkin produk lain masih 2-3 tahun lagi bisa nyamain GoPro.
4K res 12 fps
- itwilly
mantap pak.... kisaran harganya berapa untuk masing2 product ?
- reez001
iwan21 wrote:HD19 ExplorerHD Full HD 1080p FPV Video Camera with Integral Recorder
alhasil masih mantap Gopro1
minus : tidak ada display onboard/u setting ny,,,
klo mo setting harus lewat video output usb & konektor putih dkt usb tdk menampilkan osd setting
dheem2 wrote:wah mas, GoPro Hero 3-nya jangan bahas yang silver & white edition mas.. Yang silver n white mah cuman Gopro Hero 2 ganti body.. trus dicap Hero3..
4K res 12 fps
Hahahhahaaa..kisaran harganya beda jauh om sama yg 2 itu, saya coba ambil yg harganya deket2 aja deh
Iya om, dibanding yg 2 lainya, harga yg ini kan paling "ekonomis"
itwilly wrote:mantap pak.... kisaran harganya berapa untuk masing2 product ?
Kalo saya baca, harga di "sononya" mulai dari $119.99 sampe $199.99, silahkan cek sendiri deh
