Saya di pinjamkan kamera dari suhu GM tapi saya tidak tau merk atau jenis apa kamera ini
Mungkin suhu suhu gaero tau jenis dan merk kamera ini hehe
mohon bantuannya ya suhu suhu
Berikut fotonya http://img547.imageshack.us/img547/1462/fr201.jpg
danielronaldo23 wrote:Itu hd wing camera
Ilhamwrtm wrote:danielronaldo23 wrote:Itu hd wing camera
Iya udah saya search bener persis hehe thanks![]()
Untuk resolution berapa kali berapa ya?
asoenhauw wrote:Ilhamwrtm wrote:danielronaldo23 wrote:Itu hd wing camera
ini spek nya om, selamat menikmati 'racun' Suhu GM![]()
This handy pocket camera offers stunning HD quality video in a compact and light weight package. With support for up to a 32gb Transflash card (Micro SD) you will be able to shoot hours of HD 720p footage. The built in 850mAh Lipoly battery provides up to 3 hours of recording time. This camera is the perfect companion to your FPV system, allowing you to install a second camera (other than your actual FPV camera) to capture your flights in 720p HD without adding a large weight penalty to your existing FPV platform. Even if your not into FPV this tiny HD camera is great for just about any model. Strap it to your car, heli or plane and record all the action to share with your friends in HD quality.
Specs:
120 degree wide-angle HD camera lens,
5 Megapixels COMS sensor
Video resolution: 1280x720p 30fps
Selectable video quality: Superior/Standard/economic
Unique motion-detect recording function
Selectable motion-detect recording time: 10sec, 1min, 5min, 10min
Unique loop recording function
Photo resolution: 2560x1920 JPG
Built-in 850mAh Lipoly battery provides up to 3 hours of recording
Vibration alert support (Vibrates to confirm functions)
Memory slot: Transflash (Micro SD) support up to 32 GB
Size: 74mm x 28mm x 15mm
Weight: 29.4g
PC camera function
TV-OUT mode for Video play back and Funtion setup
TV-OUT modes Supports PAL/NTSC
USB2.0
Ilhamwrtm wrote:asoenhauw wrote:Ilhamwrtm wrote:Iya udah saya search bener persis hehe thanks![]()
Specs:
Weight: 29.4g
PC camera function
USB2.0
Terimakasih banyak suhu atas infonya
Kebetulan saya keponakan dari om GM (biasa main di cibeureum)
Saya kena racun terbang FPV dan akhirnya tertarik juga
danielronaldo23 wrote:Wah enak ya ada yang ngeracunin. Kalau saya ngeracunin diri sendiri. (Lah bunuh diri dong) hehehe
