charger HK variable g balance lagi.
Moderators: unding, ajo.naim
fadliputra
Post by fadliputra »
Ass..master.. kita punya kasus dng charger .. klo di cas volt nya g sama lagi.. udah sya coba stting variable nya sell perta tetap di atas 4'30. Yg laen 4.15.
ahmadbenny
Re: charger HK variable g balance lagi.
Post by ahmadbenny »
fadliputra wrote:Ass..master.. kita punya kasus dng charger .. klo di cas volt nya g sama lagi.. udah sya coba stting variable nya sell perta tetap di atas 4'30. Yg laen 4.15.
Dicoba cas dengan batre yang lain apa sama om... :hmm saya pernah kasus begitu gak taunya batrenya yang dah gak normal... :nw
fadliputra
Saya coba tes btre lipo tx t9xr hasilnya sama. Sy cek volt pake tester digital. Volt lwt 4,20 volt.. :ktk
Variable apa nih yg dirubah2?, jangan sampe variable setting arus dan tegangan arusnya yg dirubah2 ya, susah balikinnya tuh karena kita gak tau nilai preset dari pabriknya berapa
fadliputra
Variable ada 6, udah saya otak atik semu pak.. kejadiannya udah setahun yg lalu..
fadliputra
ni maksudnya gimana ya.. susah banget g bs bahsa ingris Accucel-6 is a really nice product. The firmware of thie charger is exactly same as of any other 50W charger. It has a blue backlit which is easily readable in the sunlight or in dark.
Along with the cigarette lighter adapter, you can use this to charge your batteries while driving down to the field.
http://www.hobbyking.com www.link ANY SPACES IN THE ABOVE LINK)
The buttons are good and it has all metal body which is really good as compared to the Hobby King $18.99 charger.
This charger comes with a multiple charge lead connector which you can use with any kind of battery.
You can even calibrate the charger if you feel the readings are a little incorrect.
For calibrating this charger follow these steps:
1.) Power off the charger.
2.) Press and hold the (dec" and "start" buttons.
3.) Power on the charger. (you will hear 3 beeps in a row). Keep the buttons pressed.
4.) You will enter into the calibration screen where the voltage detected by the charger is displayed on the screen (voltage on output leads).
5.) Attach any battery to the output leads of the charger.
6.) Using a digital multimeter, correct the reading of the voltage by pressing "inc" or "dec" buttons till the reading matches with that of the multimeter.
7.) Press "Stop" when you are done.
8.) Your charger is calibrated now.
fadliputra
Ripanya utuk kalibrasi tmpilan volt di lyar... :gg kirain untul kalibrasi output /sel....
Nah itu masalahnya, kalo potensio/trimpot udah diputer2 susah lagi cari preset awalnya.
Cari skemanya juga susah utk tau trimpotnya utk set apa aja
fadliputra
masalh udah KELAR pak... tp sayang nya tadi sore kumat penyakit laen.. trus saya banting tu cahrger.,... :hre :hi3
sekarang lagi mikir duit ni :ktk biar bisa beli baru.... :hmm
