ada yg bisa kasi review ngak..kelebihan dan kekurangan 2 tx ini??? help
Deskripsi lengkap:
INI YG JR
- 6 channels
- 10 model memory
- Airplane/Heli programming
- 8 character model naming
- FM or S PCM modulation
- Selectable switch locations
- Trainer and Pilot Link system
- Mode changeable
- Sub Trim adjustment
- Travel adjustment
- Servo reversing
- Dual Rate/Expo for Ail,El,Rud
- Direct Servo Control (DSC)
- Digital trims
- Adjustable sticks
- Throttle Cut System
- Failsafe System (with PCM Rx)
- Servo Travel screen
- Model Copy function
Airplane Program features:
- Flaperon, elevon & V tail mixers
- Flap system w/elevator mix
- Elevator to flap mixing
- Aileron to rudder mixing
- 4 programmable mixers
Helicopter Program features:
- 5-point throttle & pitch curves
- Normal & Stunt curves
- CCPM swash mix-90, 120, 180
- Revo mixing
- 2 programmable mixes
FUTABA 6EXHP vs JR X2610
- deka1
- prast
- deka1
- sevenslidegrills
Untuk TX dikelasnya sdh cukup bagus, malah lebih komplit menunya dibandingkan dg FUTABA 6EXH. Kekurangannya hanya tersedia 2 flight mode ( Normal dan idle 1) dibanding HITEC yg 6 ch sdh ada 3 flight mode (normal, idle 1, idle 2). Tapi untuk susunan menu saya rasa JR lebih mudah dilihat dan dipahami karena sudah ada kurva untuk throttle dan pitch.
- Major General
- deka1
- deka1
- dedy_r450
- Captain
- Budi
- Colonel
- Adrian
