mohon review dan cara break in....
olinya pake 2T yg merk apa ?
Specifications:
* Type: 2 cycle piston valve type gasoline engine for airplane
* Displacement (cc): 15cc
* Bore x Stroke (mm): 29mm*26mm
* Carburetor: Walbro Pump(made in Japan) & Made in China (Diaphragm butterfly valve
type)
* Ignition: DC-CDI (Computer Controlled auto advance, electronic ignition system)
* Power supply: 4.8-6V
* Maximum Output: 2.1 hp/1.54KW
* Speed range: 1500-15000rpm
* Gasoline-Version: Pre-mixed Fuel, 25-40 (Gasoline):1 (recommended : 30:1)
* (90% high octane unleaded gasoline, Import gas into carbon fiber installations valves)
* Lubrication Oil: 2 cycle engine oil
* Propeller: 15*8 8000 rpm; 13*8 10000rpm (Standard Two leafs prop)
* Recommended props: 13x6, 14x6, 13X8, 15X8, 15X6
* Recommended Airplane: 60 size plane, 50 size plane, 40 size plane
, gak usah dianggep)
