Kira2 reciever micro apa yg cocok dan terjangkau harganya?
Mohon Petunjuk.
The Micro Profile J3 comes with a brushed motor/gear box combo and a 3A brushed ESC pre-wired so there is no need to solder. The strong EPP foam will handle knocks and makes the J3 a blast for indoor flying. You will require 2 Ultra Micro linear servos, a 100~138mAH 1S battery and your own transmitter and receiver (Tx/Rx) to complete this model.
Specs:
Material: EPP/Carbon
Wingspan: 360mm
Length: 255mm
Flying Weight: 19g
3 Channel~2 Servo (rudder, elevator, throttle)
Includes:
GPS6 Brushed Motor/bearbox Assembly (Included)
3A Brushed ESC (Included)
Hardware
4x2.5 Prop
Requires:
Your Own 4ch RX/TX
2 x Ultra Micro Linear Servo
138mAh 1s Lipoly
