"Masih dalam Mimpi"......Gyrocopter_Project non RC!!!...
Pesawat swayasa , paralayang dan balon udara
Moderators: wa2n, christoffel
ferry
Post by ferry »
Teman-teman gaero mungkin ini hanya sekedar mimpi indah dan entah kapan bisa realisasi, hal2 yang menyangkut lisensi dari FASI juga belom saya mengerti, tetapi untuk sekedar menghibur diri krn kelamaan gak terbang, mungkin sedikit bisa menghilangkan rasa penasaran saya coba untuk menggambar rancangan modelnya dengan prinsip ATM ( Adobe, Transform, and Modification ) spt ini :
Design Head
Kemudi
bersambung!!.....
barubisaterbang
Re: "Masih dalam Mimpi"......Gyrocopter_Project non RC!!!...
Post by barubisaterbang »
:mtp :mtp :mtp
ferry
Post by ferry »
Spec Teknisnya kira2 spt ini:
Height......................................................................1.8m
Length ................................................................... 3.2m
Width..................................................................... 1.6m
Empty Weight (minus engine)....................................... 68kg
Empty Weight (with engine) ...................................... 105kg
Gross Weight (max) ................................................ 250kg
Rotor Diameter ......................................................... 6.4m
Rotor Chord ............................................................17.8cm
Disc Loading (lbs/sq ft) ........................................... 1.53
Engine..................................................................
Horsepower Range.............................................45 to 70
Maximum Speed .........................................................
Airframe construction ........................ welded steel tubing
Control System ............................ joystick; rudder pedals
Cruise Speed ...........................................................
Take-off Speed ........................................................
Rate Of Climb ...........................................................
Maximum Altitude .....................................................
Rencananya dibuat gyroglider dulu ditarik mobil untuk tahap uji coba sebelum dipasangin mesin, tapi masih mikir main blade......bisa kebeli atau nggak :whoaa
@barubisaterbang makasih kunjungannya salam kenal.....@Admin keknya salah room ya?, tolong kalo bisa dipindahkan
rachmatjeny
Post by rachmatjeny »
weehhh scale 1:1 om?
:hah :hah
:plk :plk
ferry
Post by ferry »
rachmatjeny wrote:weehhh scale 1:1 om?
:hah :hah
:plk :plk
Hehehe.....mimpinya gitu Om Jeny :thx tapi.... :htg
christoffel
Post by christoffel »
bravo om ...
saya dukung deh ...
lanjut ....
nb: nggak salah room koq ... :) :)
christoffel
boleh usul ?
saya juga lagi mem-bangun trike (pake canopy paragliding), yg ini nggak perlu ijin terbang karena termasuk micro-flight. jadi kira2 kasus nya mirip deh.
saya sudah selesai bikin perpipaan nya (buggy dari stainless steel ngelas sendiri, ban pake ban vespa, motor untuk didarat pake brushless 250 watt 16KV, batt lipo 7 cell 5000mAH dg esc 25A udah testdrive dan bisa lari 20kmph. sekarang dipakai untuk kite-buggy tiap minggu sore).
masalahnya, engine untuk bisa terbang muahal sekali .... (sudah tanya sana-sini, engine paramotor harganya hampir 50jt franco surabaya, itupun dari merek yg saya kurang sreg. engine yg saya incer harganya sekitar 90jt).
Saya pengen coba pake engine gasoline yg 110cc, itu kan 12.5HP
kalau pake 2 (twin prop) kan udah 25HP (saya perlunya cuman sekitar 20HP aja sih)
untuk om ferry karena mintanya 40HP, gimana kalau pake yg 170CC (17.5HP) atau yg 222 (21.5HP) aja 2 buah.
keuntungan pake twin, prop nya jadi nggak perlu gede, dan bisa pake prop pesawat r/c aja. gampang nyarinya. bisa juga dibuat counter rotating supaya momen puntirnya saling menghilangkan.
dan yg penting, harganya jauh lebih murah ......
gimana om ferry ...
nb: dari rekan2 di forum paragliding, saya disarankan bikin muffler sendiri karena muffler bawaan nya bakal terlalu bising padahal kita kan duduk didepan engine tersebut.
ferry
Post by ferry »
christoffel wrote:bravo om ...
saya dukung deh ...
lanjut ....
Makasih Om Christoffel, jadi inget mainan kitiran waktu kecil kalo sekarang pake yg plastik punya,....ini salah satu inspirasi diluar sana mungkin waktu kecil jg main kitiran,....teori fisika tentang energi potensial, resultante gaya, massa, dan teori grafitasi berlaku jg di mainan ini shg autogyro terjadi, sedikit premover diawal selebihnya akan berputar sendiri.....saya hanya tau kulitnya saja, ahlinya spt Om Christoffel bisa lebih detail menerangkan.....
sedikit hiburan nonton ini aja:
andreansyah
Post by andreansyah »
waduh... :tlt , mudah2an mimpi jd kenyataan om ferry......... :mwr
:tlt :tlt :tlt Ini namanya ngak mantap lagi....
:kyn :kyn :kyn tapi ini sangat hebat...!!
:doa :doa :doa mudah2..an terlaksana apa yg anda cita2kan
:mtp :mtp :mtp rekan2 aero n gaeropun tetap bangga melihat karya anda meskipun itu berhasil atau tidak..
:hl :hl :hl lanjutkan...~ :ngl :ngl :ngl
:cta :cta :cta salam..........
