Heli dengan lebih dari 1 gyro
Moderator: chandra
- Sulistiyo
Para senior... apakah sudah ada yang nyoba 1 heli dengan lebih dari 1 gyro???
- e12ry
CycLock - the gateway to electronically stabilised flybarless operation
CycLock can work in conjunction with two SL720 gyros to provide superb electronic stabilisation at a very affordable price.
The full temperature-compensated-zero stability of SL720s gives automatic speed trim in any attitude without an expensive, fragile airspeed sensor.
Keeps investment in flybarless operation to a minimum with both the gyros and mixer applicable in conventional models.
The remarkable flexibility that the PC interface of the SL720 gyro provides means it can be used for a variety of specialist applications, from camera stabilisation to wheelchairs.
Here the SL720 proves its worth by being able to be set-up for cyclic operation - a very different situation to its use as a tail gyro.
FLYBARLESS SETUP!!!!! Baby!!!!
- sudjai sarmo
- Major General
- dino
- Major
Re: Heli dengan lebih dari 1 gyro
reg
dino
- coyo
berarti gak bisa buat heli ccpm 120°
- christoffel
kalo buat aileron bisa pak coyo, pake mixer elevon nya gws. kalau buat elevator mesti bikin mixer sendiri ....
